Kenwood NV-D77GA
logistiek1
Kenwood NV-D77GA
Bericht door logistiek1 »
Wie herkent dit euvel
navigaite is bijna niet te horen, en lijkt maar over een speaker te gaan
geluid navigatie staat op 100 %
radio of cd staat aan
Gast
Bericht door Gast »
ben eigenlijk wel benieuwd of dit opgelost is. ik heb namelijk met die dnx7200 precies het zelfde probleem...
Gast
Sorted
Bericht door Gast »
heb een uitgebreide bericht van Kenwood UK gekregen over dit issue. heb het even samen gevat:
Locked AV Interface Menu.
You need to unlock your settings. First you need to check that the unit is not in Dual Zone. To do this, click on Audio Settings third icon down on the right hand-side of Main Menu. You will enter Audio Control menu. On this page you will either see Single Zone which is OK and you can exit back to Main Menu or you will see Dual Zone. If this is the case click on Zone to change to Single Zone and then exit back to Main Menu.
Now click on Set Up Menu which is the last icon on the right hand-side of the Main Menu. Page down twice and click on Set Up Memory and Push Unlock.
Low Navigation Guide Volume.
This is no problem you can change the volume and also change speaker out for the voice.
Step 1
In the main screen for the DNX7200 you will see some logo’s on the right hand side of the screen. Press the bottom one which is for Set Up Menu – the logo is a spanner. Then select AV Interface. On this screen you will see 2 green arrows – 1/ facing left and 1/ facing right, this changes pages in this menu. Press the right arrow till you get to page 3. You will now see Navigation Guide Volume which you should change to about 27. See read step 2 below. (Also on this page you can change position of the speaker output located above the navigation guide volume.)
Step 2
Now get out the Set Up Menu and go to Navigation. You will see a menu Volume Select this and turn down to about 60%. You will now find that the volume level with be OK.
Net antwoord! Laat je ons nog even weten of deze oplossing werkte?
Gast
Bericht door Gast »
yep, ga het vanavond uit proberen. kenwood zit namelijk in mijn wifes car.
Tsss. My wife zit meestal in my car :(
( :wink: )
Gast
Bericht door Gast »
als je dit volgt werkt het perfect!!!
Top!
Wellicht kan deze, geschoond van mijn zinloze :wink: aanvullingen, als 'sticky' in het kenwood-gedeelte blijven staan?
en wellicht kan bitonw het vertalen naar het Nederlands terwijl ie de procedure doorloopt op zijn toestel?
    Weergaves: 1456
    Weergaves: 797
    Weergaves: 1083
    Weergaves: 974
  • Kenwood DNX5160BTS
    Weergaves: 687
  • Kenwood Mem gir low - navigatie onbruikbaar
    door Bramski » 24 jul 2018 14:33 » in Kenwood
    Weergaves: 913
  • Kenwood DNN 9230DAB
    door mixtuur » 07 jan 2019 00:01 » in My Review
    Weergaves: 1338
Terug naar “Kenwood”
