Nieuwe firmware voor DNX 7X20 / DNX 8X20 software v2.50
satfreak1969
Bericht door satfreak1969 »
Hier kan je versie 2.50 downloaden http://www.garmin.com/software/DNX7X20_DNX8X20_250.exe
Change History
Changes made from version 2.40 to 2.50:
Fixed remote update behaviour when powered accessory is attached.
Fixed issue with postal code search on Singapore/Malayzia maps.
Changes made from version 2.30 to 2.40:
Fixed a problem with elevation basemap shading.
Fixed a problem with reading files from an SD card.
Fixed an error causing forecasts to not be displayed when using XM.
Changes made from version 2.20 to 2.30:
Fixed a problem that would display the unit id as a negative number when updating maps.
Fixed a problem that could interfere with a map update if a pop-up message occurred.
Fixed a translation problem with British English
Fixed a problem with the elevation basemap not drawing in 2d mode.
Removed a message that may pop-up if WAAS was enabled.
Added support to correct problem if 'Maps are locked' message appears.
Changes made from version 2.10 to 2.20:
Pressing on the next turn distance and time on a custom map tab will repeat the next turn instruction.
Added code to prevent the loss of map unlock codes.
satfreak1969
Het updaten van mijn eigen DNX8220 wil niet lukken :(
Ik heb een nieuwe Kingston 2gb kaartje gekocht,...geen HC...dus gewoon een langzame.
Volgens de site van kenwood moet je een mapje garmin aanmaken en daar het update-file inlaten copieeren.
Dit heb ik allemaal zo gedaan en heb dit daarna gecontroleerd,..GUPDATE.GCD staat in de map garmin :wink:
Dan stop ik het kaartje in het toestel,....alleen gebeurt er helemaal niets !! Wie weet wat ik verkeerd doe ??
Installation Instructions
Create a 'garmin' folder on an SD data card (must be at least 16mb space available on the card).
Download the appropriate self-extracting archive file onto your hard drive.
Run the downloaded executable file.
Click on Browse and select the SD card reader in the list, then select the 'garmin' folder.
Click Unzip to save the files onto the 'garmin' directory on the SD card.
Wait for the message that the update was unzipped successfully and close the updater.
Safely remove SD card from PC.
Insert SD card into Kenwood Navigation System. If there is already a card there, temporarily remove it.
Your Kenwood Navigation System will ask if you would like to update software. Answer 'Yes'.
The update will begin. Do not power off unit while the update is in progress. When finished you can verify the update by checking the version number in Menu->Settings->About->Software.
Remove SD card.
Volgens de instructies die je zelf hebt bijgevoegd niet!
Je moet de ontvangen zelf-uitpakkende file uitvoeren en niet kopiëren. :oops: Als er naar een bestemmig wordt gevraagd moet je de map Garmin op de SD kaart aanwijzen.
satfreak1969
Dan lees je mijn berichtje niet goed denk ik.
Ik heb dus alleen op de sd-kaart het mapje garmin aangemaakt....Create a 'garmin' folder on an SD data card.
Daarna heb ik het executable file gedownload en opgeslagen op mijn harddisk.
Dat heb ik gerund en het laten uitpakken op de sd-kaart in de map garmin....Click on Browse and select the SD card reader in the list, then select the 'garmin' folder.
Dus ik heb het precies zo gedaan als het staat vermeld in de instructions !!!!
Maar als ik de kaart in het toestel steek gebeurt er niets !!! Of moet ik soms een 15 minuten wachten ???
Ik had je berichtje wel goed gelezen maar aangezien je kopiëren schrijft was ik bang dat je daar een vergissinkje had gemaakt. Kopiëren is iets anders dan uitpakken :oops:
Even zo vrolijk een vervelende zaak dat het niet werkt. Maar maak je om de postcodes in Singapore en Malaysia geen zorgen :wink:
satfreak1969
nee die postcodes heb ik ook niet nodig,....maar er zit versie 2.2.9 in het toestel. Was namelijk 1 van de eerste !! Dus er zijn wel wat Bugfixes voor mij. Hoelang duurt het normaal vanaf het moment je het kaart in het toestel steekt ??
Geen idee :!:
Maar de unit moet om te updaten wel op Navigatie-mode staan meen ik gelezen te hebben
Piet22
Bericht door Piet22 »
De instructies in de Garmin-FAQ zijn iets afwijkend:
Question: How do I update the system software on my Kenwood navigation unit?
Answer:
Some Kenwood navigation units are powered by Garmin. You can download system software from:
http://www.garmin.com/products/kenwood/
To use the software on the Kenwood navigation unit:
Create a Garmin folder on an SD data card. You must have at least 16 MB of space available on the card.
Click Browse and select the SD card reader. Select the Garmin folder.
Click Unzip to save the files in the Garmin directory on the SD card.
Remove the SD card from the PC.
Make certain the Hideaway Navigation System is off.
Insert the SD card into the Hideaway Navigation System. If there is already a card there, remove it first.
Turn on the Hideaway Navigation system.
Your Hideaway Navigation System prompts you to update software. Answer Yes.
The update begins. Do not power off unit while the update is in progress. When the update finishes you can verify the update by checking the version number in Menu>Settings>About>Software.
Remove the SD card.
Last modified on: 03/14/2008
Zoals ik dit lees moet het systeem dus juist niet op navigatie staan, dus op de tuner o.i.d.; dan de SD-kaart er in en dan de navigatie aanzetten. Als dat niet lukt, kan je ook de unit via het contactslot even uitzetten zodat je zeker weet dat het navigatie-systeem opnieuw opstart.
hanspost
Bericht door hanspost »
Deze week had ik exact hetzelfde probleem. Er leek niets te gebeuren, maar toen ik de moed al opgegeven had en voor de zekerheid even naar de software keek was het ineens 2.50! Ik weet helaas niet meer of het systeem op navigatie stond of op tuner.
Volkswagen Passat Comfortline Bluemotion
Executive Plus pakket + TomTom740 + alarm!
    Weergaves: 2370
    Weergaves: 741
    Weergaves: 960
  • update voor een DNX-7200
    door veensco » 10 aug 2017 20:47 » in Kenwood
    Weergaves: 1050
  • nieuwe kaarten 965.xxxx.
    Weergaves: 1062
  • Nieuwe dvd voor NVE-N099P
    Weergaves: 2099
  • nieuwe kaarten 985.xxxx
    door japie57 » 17 feb 2017 13:15 » in TomTom
    Weergaves: 1903
Terug naar “Kenwood”
