Inbouw- en aansluittips voor Philips Carin 959 / 522
mattiozzi
Bericht door mattiozzi »
Thanks for the information.
I have need of the produced code of the cable and one photo.
The cable that i want me is the same to what you have post me to me but is many longer (various meters of length)
M@rco
what i showed is a adapter cable.
If you want a whole cable of serveral meters, then aerowswift provided you already a link for that cable.
This cable is also mentioned and pictured on the home page of te person in the by aerowswift mentioned link, http://www.navco.nl/product_info.php?cP ... ucts_id=58 .
So i'm not sure now what you want/need.
I had the feeling that you wanted to make one by you'r self because you asked for the code, but now i understand that you also could have ment the article code, which (on the Navco site) is CA12666 .
mattiozzi
It's that one !!!
You are been very kind and profit !!!
Into my Motorhome I have endured a theft (have stolen the monitor to me of the Carin) and the cable has torn me and had need to find of one new why in Italy more from many years is not found here.
Thanks to your signalling I have been able to make the purchase and I have bought also the Navco V-522 DVD Interface
I think the honour should go to aerowswift :lol: :D
But good thing that you're helped, and that Navco ships to Italy.
mattiozzi
@ aerowswift : thanks !!!!!!!!! :P For distraction, I had not seen its post :roll: It's a very nice Forum Site !!!! :wink:
aerowswift
Bericht door aerowswift »
no problem ....glad i can help somebody...
Lol
VDO
Bericht door Lol »
Geweldig maar denk er wel aan dat bij de inbouw van de monitor ook de helderheidsregeling die reageert op omgevingslicht niet meer functioneert!.
Dit betekent dat je scherm altijd in de laagste helderheidsstand zal overschakelen omdat het oog "denkt" dat er geen licht op valt en dat het relatief dus donker is.
Re: VDO
Lol schreef:Geweldig maar denk er wel aan dat bij de inbouw van de monitor ook de helderheidsregeling die reageert op omgevingslicht niet meer functioneert!.
Papegaaien heet dat, Gerritje schreef eerder in dit draadje:
"Geweldig maar denk er wel aan dat bij de inbouw van de monitor ook de helderheidsregeling die reageert op omgevingslicht niet meer functioneert!.
Dit betekent dat je scherm altijd in de laagste helderheidsstand zal overschakelen omdat het oog "denkt" dat er geen licht op valt en dat het relatief dus donker is."
Kennelijk jouw manier om aan de twee postings te komen die je nodig hebt om te kunnen downloaden.
Je andere posting heeft ook al zo'n hoge toegevoegde waarde :twisted:
Hoewel een bijdrage in principe op prijs wordt gesteld vertel je iets dat niet klopt.
Dat komt er van als je een eerdere posting van mij klakkeloos kopiëert.
Ik had het toen niet bij het rechte eind :oops: Dat bleek meteen al bij de volgende bijdrage.
Voortschrijdend inzicht zou iemand anders dit noemen.
Als je bij de monitor de 3 knoppen tegelijk indrukt kom je in het OSD menu en bij Brightness Control kun je deze vervolgens op Auto of Auto Off zetten.
Daarmede is het door jou geconstateerde euvel van lage helderheid opgelost.
Echter, het oog voor de brightness control zit net boven de IR ontvanger aan de voorzijde van de monitor en blijft bij inbouw op de juiste manier nog net operationeel. Het hele probleem is daarmede uit de wereld!
Het enige euvel bij inbouw is de onbereikbaarheid van de knoppen bovenop en het onbruikbaarheid van de luidspreker.
Edit: ik zie dat JW's harde schijf nog niet toe is aan defragmentatie :!:
spark
Bericht door spark »
wmp schreef: 2: inbouw schema Carin zou volgens mij de juiste moeten zijn
Hoi mensen,
Ik heb me net ook aangemeld hier omdat de aansluit sticker van mijn 22RC959/00 is verdwenen.
De sticker met modelcode en serienr. maar ff opnieuw vastgelijmd.
Maar nu wouw ik dus een aansluitschema hebben om hem weer aan te kunnen sluiten.
Ik weet zo namelijk niet meer welke kleuren op de groene stekker zijn voor de achteruit en het puls signaal.
(tenminste ik geloof dat deze in de groene stekker zaten.)
Alleen werkt voor mij de bovenstaande link dus niet?
Kan iemand mij verder helpen.
(ps. ik hoop dat hij niet om een inbouwcode vraagt om weer te kunnen werken. heeft namelijk zo'n 6 jaar in de auto gezeten zonder dat ik de toenmalige code opgeschreven heb. (ja ik weet DOM))
Probeer even http://www.navigatiehelpsite.nl/forum/d ... l&df_id=37 , dat werkt wel.
En je hoeft niet bang te zijn voor een code, die zit er niet op :wink:
spark
JW schreef:Probeer even http://www.navigatiehelpsite.nl/forum/d ... l&df_id=37 , dat werkt wel.
Thanx ik ga het ééns proberen deze week.
    Weergaves: 1114
