[INFO] IVSC 1102 - InCar Video Signal Converter
Blaupunkt IVSC 1102
Power Supply 10.8 V … 16.0 V
Functional temperature range 0-20 to +70 Celsius
Operating temperature range 0-40 to +85 Celsius
Storing temperature range 0-40 to +85 Celsius
IN/OUT
Composite AV Input 1
Composite Monitor Output N/A
Navi (RGB) Input Yes
Navi (RGB) Output Yes
stereo line input N/A
stereo line output N/A
IR Receiver N/A
Termination of the RGB input N/A
Video characteristics
RGB Input impedance 75 Ohms
RGB Output impedance 75 Ohms
Maximum RGB input/output level 0.7 Volt
Audio characteristics
Booster Gain 10dB
Input impedance 10 kOhms
Output impedance 1.1 Ohms
Maximum input level 1THD 0.6 Vrms
Frequence Response (kHz=0dB) 20Hz ~ 20,000Hz
S/N Ratio 65 dB
BLOCK DIAGRAM
Composite Video-to-RGB signal converter Yes
5/5 video crossbar switch and 5/5 audio crossbar switch N/A
3/3 video crossbar switch and 3/3 audio crossbar switch N/A
RGB-to-Composite Video signal converter N/A
10dB audio booster N/A
Voltage regulator Yes
IR Receiver N/A
Accessories
Power Cable Yes
Remote Control No
Remote Eye (Cable length : 5 m) No
Manual Yes
Color tapes (Size :500mm x 100mm) No
Mounting screw Yes(4ea)
    Weergaves: 758
