Hello from Germany,
I found this Forum, and it seems, that all VDO Dayton Experts are here. In Germany, nobody was able to answer my questions, so now I try here. I don't speak your language, and my english is not the best, but I hope, you understand.
I want to install my "old" PC-5200 in a new car, and expand with Multimedia. My equipment is:
- PC-5200 Navigation System,
- MM-2100 Monitor,
- MM-5300 Monitor,
- MI-2200 Multimedia
- DV-6100 Player.
1. If I connect the MM-2100 to PC-5200, it works. If I connect
the MM-2100 to MI-2200 I get no picture. Why?
2. At the PC-5200 there's an "accessory" Pin (A5). For what it is?
3. At the MM-2200 is a little jack-connector in the cables, that
should be removed for use with DV-6100. The jack seems to
be empty and not wired. For what this is?
Thank you !!!!
Volker
PC-5200, MI-2200, MM-2100, not working, different questions
Weergaves: 607
Weergaves: 702
Any updates and maps for VDO VRM 6200 + PC 5200/40?
door Driver.Yo » 14 aug 2017 21:47 » in Vaste VDO-Dayton systemen -
Weergaves: 768
